Results 1 to 2 of 2
Thread: Rear brake pad replacement
    Glasgow
    Cool Rear brake pad replacement
    When replacing the rear brake pads is it necessary to remove the whole caliper housing or can the caliper be swiveled on one of the housing retaining bolts. Petrol 1.8 Vectra C 08 plate.
    When screwing the cyling back is it CW or ACW?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Larry
    remove tension spring,rubber seal from guide pin's,remove guide pin's,remove brake calliper and outer pad from frame,remove inner pad from calliper,screw piston into housing CW.(don't let calliper hang on flexi brake hose,)I use long nosed pliers or cerclip pliers to screw in piston.it's an easy quick job.(you will have to ease guide pins out of calliper with a screw driver to clear frame for caliper removal
  1. Rear brake replacement advice
    By jammy_c in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2013, 00:45
  2. Brake pipes need replacement.help?
    By Dobs in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2012, 22:46
  3. How much for brake pad replacement?
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2009, 19:53
  4. Vectra Rear Hydraulic Brake Line Replacement ???
    By Markuk27 in forum Handling & Braking
    Last Post: 20th May 2009, 02:35
  5. rear brake pad replacement.
    By mick 1986 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2009, 09:47
