Results 1 to 10 of 21
Thread: Air-con recharge £25.
    hull
    Default Air-con recharge £25.
    May be of use to some with the weather warming up a bit.
    http://www.hotukdeals.com/item/63784...harge-kwik-fit-
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    Quote Originally Posted by frasedeb View Post
    http://www.hotukdeals.com/item/63784...arge-kwik-fit-
    I clicked on the links to Kwik Fit and it's not showing the aircon deal
    Jon
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Quote Originally Posted by blues n twos View Post
    Jon
    just call in mate- mine was done there last year
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Mine too, still fine so far
    Oct 2009
    CRAWLEY,WEST SUSSEX
    I would'nt let Kwik fit any where near my car!!!!!!!!!
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Honestly guys, this is one thing that you can let them touch, the machine does it all for them
    Oct 2009
    CRAWLEY,WEST SUSSEX
    Still would'nt trust them, not even to change a light bulb!!!
    They tried to convince my missus that her car needed a back wheel bearing after they replaced the exhaust, as there was a rubbing noise after, I had a look, and the exhaust that they had fitted was rubbing on the tyre. I took my car to them ,a Cavaliar to get tracking done, was told by the Kwik fit Fitter , that track rod ends were seized, and they could'nt be shifted, idiot did'nt realise that the track rod ends come off, one side clockwise , the other anti clockwise!!! total cowboys in my opinion.
    As I said would'nt let them anywhere near my motor
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Quote Originally Posted by Ianz View Post
    Quote Originally Posted by r.bailey63 View Post
    i took the vectra to them once for the rear knocking, the guy checked it over and said nothink was wrong, i new there was changed the shocks and all sorted, and a friend of mine had a mk2 golf they fitted new brakes for him and when he was on motorway and he wanted to use his brakes and they wouldnt work he had to use the gearbox to slow him down called the RAC out and they took him back to them, but they claimed it wasnt there fault but they would do it as good will, good will my ass, i dont like going to them
    Regular Member RobW's Avatar
    Tain - Easter Ross
    What they said.
    All they would do is top it up. For it to be effective they would need to empty the system, vac it to get all the moisture out then refill. I doubt they would do all that for £25!!
    Best bet (as I have said before) is to go to a fridge repair man. They will do it all properly and will use a better gas (R413a as opposed to R143a) - it will repel more moisture and will lubricate the seals better than the lower rated gas.
    I have a chap locally who does mine for a poke of chips!
  1. Air Con Recharge
    By garetmcc79 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 16:41
  2. K&N Recharge
    By spennny in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 15:05
  3. Air-con recharge
    By frasedeb in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2010, 10:17
  4. AC recharge cannisters
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2009, 19:46
  5. Air Con Recharge £25
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2009, 19:36
air conditioning recharge dunstable
car air conditioning recharge dunstable
