Thread: EML + swirl valve bar off..what needs replacing
    Regular Member marky2027's Avatar
    Northumberland
    Default EML + swirl valve bar off..what needs replacing
    Had the dreaded EML come on this morning. Recently had EGR valve replaced and so suspected it was the pesky swirl valve linkage as thanks to this site had already noticed it was a tad loose. The whole bar is not off but half of it is (first two from the left). It's not all bad news though as thankfully I paid for AA breakdown repair cover. AA have been, I pointed it out, he wrote a report and taking into dealers today. They can't look at it til wednesday so it gives me a chance to find out exactly what needs doing. Along with the new inlet manifold what else should be done??
    Regular Member P3tchy's Avatar
    Milton Keynes
    Its not the bar that causes the EML, its the swirls have worn out so much that they leak air. The ECU picks up on this and throws up the light. The bar is just a side effect of it being worn out.
    Needs a new Inlet manifold and swirl valve actuator.
    Northumberland
    Quote Originally Posted by P3tchy View Post
    Cheers mate! Is it standard practice to replace the manifold AND the actuator or could dealer pull a fast one and say it only needs new manifold?
    Milton Keynes
    The actuator is a one time use motor, when you connect it and switch the ignition on it programs itself to the movement of the swirl cups, Supposidly it cannot be used on a different manifold, I have heard of ppl just doing the manifold and dealers saying the motors not needed but I didn't fancy removing it all again just for the sake of a £150 motor.
    Northumberland
    Got you. I prefer to be armed with this info before going into dealers so i know I'm not being duped!!
    Milton Keynes
    Is it being done under warranty? if so its in the technical reference, recommended by Pierberg to change both the manifold and the actuator.
    Northumberland
    No it's out of warranty but I do have AA breakdown repair cover. How much would I be looking at for the manifold, actuator and labour?? Should I chase VX to make a contribution towards the cost??
    Regular Member Kenny1969's Avatar
    Jan 2013
    West midlands
    Hi...I have been wondering about having the aa repair breakdown service..could you tell me if it is worth while...did you get the manifold done with the aa paying up..I ask as I have bought a vectra c 1.9 cdti and after hearing the stories about the swirl flaps etc wondered if it was worth while having...I know it's an old thread now but just thought I'd ask
    cheers
    Northumberland
    Quote Originally Posted by Kenny1969 View Post
    cheers
    PM replied to mate
    Jan 2013
    West midlands
    Cheers mark
  1. EGR valve - when has yours needed replacing?
    By MrT in forum Engine & Drivetrain
    Last Post: 5th October 2013, 19:16
  2. Interesting find after replacing EGR valve
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2012, 19:11
  3. Egr valve, swirl valve problems etc..
  4. Replacing tyre valve ???
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2006, 19:45
valve swirl off
vectra swirl flap eml
