Results 1 to 10 of 13
Thread: inlet manifold day!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default inlet manifold day!
    Ok guys its 'replace the manifold day tomoz!!, any tips or tricks to ease the job ?, Where's the best location to drain the coolant from ?, It only needs to come half way down the block realistically, While im at it! the failed swirls are quite worn!, and i have a LOT of oil deposits in the manifold valley, So where is it coming from ??, I don't need to top up in between changes, and it must be coming via the inter cooler, so therefore am i correct in thinking its by-passing the turbo seal ? Is it common to have much oil as mine is quite a bit , i know they get gunky but this is OILY.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    it seems quite a job but you can do it diy not sure if you can do it without taking the timing belt off???
    the oily deposits come from the egr valve and it is mixed up with soot and also oil from the breather so its normal to see it if your manifold has failed
    also when changing your manifold i would suggest a new egr valve def a new swirl motor s these should be changed with the manifold and if you have funds a new boost sensor if it looks bad
    also new manifold seal and be sure to get all the old seal off and not to chip or scratch the face of the block
    hope this helps mate
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    any advise will be taken on board!, and Ive been routing for bits, it can be done without taking the cam belt of, but I'm unsure regarding the oil deposits, it will not come from the egr as this is of hot dry sooty deposits, the oil separator/breather as i can see don't come in to it, that just leaves the inter cooler pipe witch as i presumed was a seeping turbo seal ?, just need some feed back from some who have had this to see if they left it or looked into it.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Not much help then??, ahh well its done now!!.
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    Did you run into any probs with it?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    No problems but its a pig of a job!, i would allow a full day, the oil separators a git to get off, diesel pump was easy but care has to be taken, overall if your not competent with mechanics i wouldn't tackle it, i also fitted the fiat semi blanking egr gasket with no problems , she's running sweet!. TOTAL parts 1 inlet manifold, 1 gasket, 1/2 doz jubilee clips i already had, TOTAL cost £104. .
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    no new nuts or anything? Was thinking of doing this one myself... Gonna take a few days off and do it when its warmer, much warmer lol
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Nothing other than an inlet manifold and gasket and assorted jubilee clips, if you have the right tool for undoing and redoing up the vx clips you can re-use them all, but i found it took to long messing about with them.
    Regular Member P3tchy's Avatar
    Milton Keynes
    Did you not change the actuator that controls the Swirls?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    NO!, you realy dont have to, and most vauxhall dealers dont, im always in at the local vx spares counter and they order just a manifold and a gasket when they do the job, they even re-use all of the hose clips. if vx do it then so can we.
  1. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  2. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  3. Inlet Manifold Done
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 12:32
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  5. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
witch bit is the inlet manifold vauxhall vectra
