Thread: Colouring boot strip
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Colouring boot strip
    Its been something I have wanted to do for a while but have never looked into it properly.
    How does it come off and what is the best method for painting it? Obviously its going to be black but does it need 'roughed up' first and is there a certain primer needed?
    Tain - Easter Ross
    Cambridgeshire
    There are a couple of nuts that hold it on at the back, also the clips keep it in.
    In terms of painting...I might have one for that I could sell to you soon if you're willing to wait? (Painted black sapphire)
    Regular Member sristeven1's Avatar
    wirral
    removel is easy open boot there are to nuts either end then you gotto remove the boot lining to get to the other 2 bolts as for spraying there will be some one on here that will help you with that mate
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    if you don't buy scott's then a rub down with 1000 grit wet n dry paper to give it a key - wipe clean - primer - dry - another more gentle rub down - wipe clean again - apply paint about 2-3 coats and let dry - laquer - dry - laquer - dry - polish up and re-fit....
    HTH
    Midlands Mod Shop - NFFC.
    Tain - Easter Ross
    Quote Originally Posted by parsco View Post
    Hmmm. Interesting. Drop me a PM when you know more.
    Quote Originally Posted by sristeven1 View Post
    ****, I hate taking the boot lining off. Couldn't get it back on properly last time.
    Cambridgeshire
    PM sent mate
    Regular Member Lightboy's Avatar
    May 2007
    Reading, UK
    Quote Originally Posted by ditchp View Post
    HTH
    Rich, I'm doing mine at the mo, is it right that you need to 1200 grit wet&dry the final paint coat to make it matt before you laquer??
    Thx
  1. Red boot strip please
    By RichM in forum Photoshop section
    Last Post: 5th January 2013, 12:29
  2. How 2 for boot strip
    By Carl83 in forum Styling
    Last Post: 31st December 2012, 00:20
  3. Boot strip
    By new boy in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2011, 20:27
  4. boot strip
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2011, 14:17
