Results 1 to 10 of 17
Thread: headlights?
    Milton Keynes
    Default headlights?
    I have the chrome headlights that came standard with my sxi....I want the sri smoked ones but looking at the how2 it can be done by spraying the chrome.... but the how2 looks difficult envolves cutting very carefully which I'm not good at....
    cant the headlight cover just be removed... looking at the lights it kind of looks like a case of removing them, remove the seals and jsut popping the cover off, then I have access to the chrome surround? is this the case?
    Hanging Heaton / Batley
    16 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Yes, the lense part comes away from the rear. then the chrome slips out...
    If you have access to an electric oven it makes the whole process 10 times easier
    Milton Keynes
    haha why the electric oven?
    so I can just remove the seal, then unclip the cover?
    that will be next weekends mod I think.... simple enough it sounds... I guess it wont be as per usual something will go wrong!
    Regular Member badback's Avatar
    Runcorn
    The lens is glued on mate, the electric oven is to soften the glue.
    16 Post(s)
    Mileage : 110k
    If you heat them up on a low heat it'll come away very easy... I put my MK4 astra lights in there at 50'c for half hour - turn occasionally, for fan assisted ovens please see manufactures handbook
    Full Member Big Sig's Avatar
    If your going to do them dark, why not colour code them?
    Milton Keynes
    ahh so cooking them helps... so about 40'c for half hour should soften them up enough to pull away? then I can just re seal it with sealent?
    Milton Keynes
    Big Sig.... that was my next poll I was going to do... I think i'll have to actually do a poll and see!!
    Cara did them in her Signum many moons ago, looked great
    Milton Keynes
    I thought about it.... not sure, i was thinking the black would follow with my grille.... but then again the colour coded would look good... need too see some piccys to sway me!
  1. LHD / RHD Headlights
    By 24vElite in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2011, 19:46
  2. headlights
    By SimonL in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2010, 12:50
  3. headlights dim
    By iasha in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 16:26
  4. SRi Headlights
    By Danwells72 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 20th October 2008, 09:11
  5. Headlights
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 17:55
