Results 1 to 3 of 3
Thread: Is clutch and flywheel inside gearbox?
    Redcar
    Default Is clutch and flywheel inside gearbox?
    I was wondering if i bought a gearbox second hand are these parts inside it. cheers
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If you unbolt a gearbox from the engine, the clutch and flywheel are the parts remaining on the engine that you see when the gearbox is moved away. Clutch mounted to flywheel... flywheel mounted to the end of the crankshaft.
    The removed gearbox should contain the clutch release assembly visible in the bell housing, but the gears are all nicely sealed in the main casing of the box, with lots of lovely oil slopping around them.
    Jan 2010
    glasgow
    as andy said but imo id would put a full clutch kit on it then no worries that u have to pull the f***** back off if the clutch gives up the ghost in 3-6 months time
  1. gearbox + flywheel advise........
    By vectra gsi 3.2 in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2013, 10:52
  2. New flywheel and clutch :(
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2010, 16:20
  3. Flywheel and clutch kit!
    By fizler316 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2010, 23:11
  4. does 2.2 clutch and flywheel fit 2.0 DTI???
    By darrenjack in forum Engine & Drivetrain
    Last Post: 28th April 2010, 17:05
  5. gen clutch dm flywheel
    By vecdti in forum Parts for sale
    Last Post: 9th November 2008, 22:02
