Results 1 to 2 of 2
Thread: egr valve ?
    grimsby
    when you split your egr valve for cleaning should the centre pi of the selenoid be in or out mine is just about flush?
    hi got fault code p0400 egr flow malfunction .taken it off and cleaned all the gunk out .refit egr valve canceled fault code and run engine up.two mins later same fault code again what do you think i should do next?
    engine still seems to run as good as ever.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    OUT!!, LIKE IN THE PIC'S HERE!!, WHEN YOU SPLIT THE EGR YOU SHOULD ALWAYS PART THE SOLENOID AND CLEAN THAT!, CHECK THE HOW 2 SECTION AND CLEAN all PARTS!, IF YOU HAVE THE CDTI THEY ARE KNOWN FOR BEING TROUBLESOME.
    http://www.vectra-c.com/forum/showthread.php?t=101414
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
