Thread: A/C spin up noise
    South East
    Default A/C spin up noise
    When I first press the A/C button (after sitting for X number of hours) it makes a spin up type noise like pressure is being achieved but slightly grating sounding. After 2 seconds the noise will pass and it does not come back until left overnight etc. If you turn it off for a while and then back on this noise will not happen.
    A/C is cool and woking although not as cold nor quick acting as my B veccy although it has been very hot of late.
    Also the load placed on the engine is more then on my 2.0 vectra B.
    The A/C has been in use frequently over the years.
    2.2 petrol
    M
    Regular Member S888 SRB's Avatar
    May 2006
    Hemel Hempstead, Herts
    Try having it regassed first, by a specialist company.
    If you still have a problem at least you know its not down to a lack of gas.
    I'd say you are low on gas but not entirely empty. Different cars produce different symptoms when this happens.
    South East
    Quote Originally Posted by S73VE B
    Thats what I was thinking as the noise is a build up of pressure (maybe not) and why its not as cold as it should be. Although it is cold.
    Regular Member Tim2100's Avatar
    Walsall
    Sound like you need a re-gass.
    My car was doing this, plus the aircon was ****. Found somebody on the net. Came out to my work next day, re-gass for £49 or service & Re-gass for £59.
    It works great now.
    Tim.
    South East
    Tim was it making the noise(only on first start-up) + a bit to much load on the engine?
    M
    Nicking Ya Dinner.
    You should hear it engage, but it's not an alarming sound, if you have a bad sound coming from it, get someone to turn it on while you listen to the pulley, it should be on the drivers side of the engine at the front, just forward of the timing chain.
    Walsall
    Quote Originally Posted by vectrasri03
    M
    Yup, only making the noise when the aircon started. Once the pressure was there the noise stopped.
    Not sure how much load it put on the engine as I only turned it on once I was going.
    Tim.
  1. Replies: 4
    Last Post: 4th December 2012, 01:28
  2. Niggling Wheel Spin
    By starykokot in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2011, 10:22
  3. After a morning detail and a spin
    By Derek Mc in forum Detailing and Car Care Discussion
    Last Post: 14th September 2010, 15:27
  4. traction control/wheel spin
    By Mike57 in forum Diesel Engine related
    Last Post: 6th June 2008, 19:47
  5. Slide / Drift & Spin
    By Swatty in forum Comedy & Humour
    Last Post: 8th October 2006, 10:16
