Results 1 to 10 of 14
Thread: Changing coolant
    Regular Member eaglepva's Avatar
    Up North
    Default Changing coolant
    Hi, I have owned my car for nearly 3 years and has never had a coolant change. i have been told that is should be done every 2/3years. Does anybody have a how 2 on changing the coolant as would rather do it myself than put it in the garage.
    Also whats the best coolant to put in i think i need 8.2ltrs.
    West Yorkshire
    Is there anything visibly wrong with the coolant? I have to say, the need to change it is a new one on me...
    Full Member spennny's Avatar
    Blantyre
    Better get the vauxhall coolant mate,
    I removed my front bumper for easier access, there is a drain plug on the lhs of the rad standing
    Looking at the car, once I drained mine out I put the vx recommended qty in and then started the car with
    The cap off, then topped up with water, not had any issues :-)
    Up North
    As far as i know their is nothing wrong with the coolant but its just come back from Vauxhall after a recall and they done a health check and said that brake fluid and coolant should be changed every 2/3yrs
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Brake fluid, yes - over time it will absorb moisture and lose performance, so every 2-3 years isn't such a bad idea.
    I think the idea with coolant though is more to completely replace with the correct mix every few years, based on the idea that most people will top-up with water and thus gradually dilute the mix. But I'd say as long as you use decent quality antifreeze and when tested the mix if correct/sufficient then why change it ?
    East Midlands
    Quote Originally Posted by eaglepva View Post
    Think they were after your pennies m8,brake fluid technically need not be changed for the life of the car,allthough it's not reccomended,also coolant should last the life of the car,providing it's topped up with anti freeze and water at the correct viscosity/mixture.
    Also any pink anti freeze/coolant can be used,and not necessarily vx stuff.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    wouldn't worry either
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Why not buy an antifreeze tester for a few pounds and test it for yourself..
    it should tell you the level of protection your getting i.e. protection down to - ??degrees C...
    Full Member Big Sig's Avatar
    I thought the pink/orange stuff is long life and is supposed to be 5 year changes?
    5 Post(s)
    Quote Originally Posted by Tony W View Post
    Some of the modern antifreezes give false readings on the floating ball testers.
  1. Coolant
    By tubby in forum Engine & Drivetrain
    Last Post: 16th November 2012, 21:36
  2. Coolant on 1.8 sri
    By Denbo in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2011, 23:51
  3. Changing coolant - did I do it right?
    By mohojo in forum Engine & Drivetrain
    Last Post: 10th August 2009, 21:30
  4. uh oh im using coolant
    By mattolly86 in forum Engine & Drivetrain
    Last Post: 12th January 2009, 22:12
  5. V6 Coolant
    By aaruck in forum Engine & Drivetrain
    Last Post: 5th October 2007, 17:45
