Thread: Bleeding brakes?
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Default Bleeding brakes?
    2007 SRi estate
    I cannot get the ****ing brakes to bleed up correctly?!!?! What am i doing wrong?!
    Using Gunsons eezibleed to pressurize the system.. now, Im led to believe that you start with the n/s rear then the o/s rear, then n/s front and last o/s front.. is this correct?
    Once it looks like all ok, start the car and the pedal drops to the floor when pressed, then when pumped becomes hard (oooerrr)
    Orrrrr if anyone is close to Luton that is a clever dick and has time to help me then please do!! Need the car sorted asap meant to be going out lol.. been on it since 6.30
    Have to go to London shortly so will check when i get back, should be about 10-10.30 ish
    Thanks in advance.. Craig
    Sunny Dartmoor
    I always start with the one furthest away from the master cylinder and then do the opposite diagonal one,so do the o/s rear 1st then n/s front then n/s rear then o/s front,thats what i was always told,hth........
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I did mine the other week with an easibleed...did you make sure you only had 20psi in your 'donor' tyre and work in diagonals as said??..
    Did you run the bottle empty and introduce air??..
    oh well.. I tried..
    Quote Originally Posted by glenboy View Post
    Gonna go try that now
    Quote Originally Posted by nikroc View Post
    Yep only had 20 as instructed, bottle still half left
    oh well.. I tried..
    Just 2 words
    1. Bell
    2. End
    Helps if you get the calipers on the correct side of the car
    After i swapped them to opposite sides and bled them up... that helped no end!
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    one word.... twit... Happened to me as well lol
    Sunny Dartmoor
    Glad you got it sorted m8............)
  1. bleeding brakes
    By mon in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2013, 21:50
  2. Bleeding Brakes - Which Kit??
    By TonyP2020 in forum Suspension, Wheels & Brakes
    Last Post: 24th March 2012, 21:26
  3. Bleeding Brakes - Few Q's
    By yoclick in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2010, 17:10
  4. Bleeding brakes tool
    By Lao in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 13:24
  5. Bleeding Brakes
    By Danwells72 in forum Handling & Braking
    Last Post: 8th August 2009, 22:43
