Thread: Air con radiator
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default Air con radiator
    Today i noticed when i opened my bonnet whilst having a broken spring replaced that i have a damp patch on the passenger side of my air con radiator,it looks like a small stone passed through the slats on my irmy grille and hit the rad.Now the question is can i get the hole sealed up some how,or do i need it replaced?.if it`s the latter how much am i looking at?Cheers
    Regular Member P3tchy's Avatar
    Milton Keynes
    I have this as well, AC condenser is fine but it was the intercooler behind it that has popped and made it look like the Condenser.
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    If you have a hole in the A/C system you will have lost the refrigerant gas and A/C shouldnt be getting very cold, need to replace the part and have the system leak tested and re gassed, leak test and regas should cost no more than £50,
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Around £140 for a new one:
    http://www.automotive-air-conditioni...L&Model=VECTRA C&part=Condensers
    Mileage : 000
    Had you just washed the car? as I find when I wash mine I must spray water through the grill some how, and I some times find there is a damp patch in the bottom right corner. But the air con works ok.
    Derry
    I had just washed the car a few hours earlier,the air con rad was dry except for a small patch about 3/4 of the way up.Will this do any damage to the car if it`s not sorted soon,btw i never use the air con system.
    Mileage : 000
    You might not have a leaking "rad" it might just be water from washing the car. But if you do not use the air con, then the seals in the pump dry out and the gas then escapes, thus no air con. It is advised to use the air con at least once a month, to keep the pump and the rest of the system in working order.
    Derry
    this might sound thick Ed,but how do i turn on the air con?turn the temp down to the cool and push the button?Btw i had a look today about an hour after my wife came back with the car and the radiator was dry all over.
    Mileage : 000
    Quote Originally Posted by VECTRA HEAD View Post
    Whilst mine is "climate control". I think you are correct in what you said. Press the air con button, then if the tempretue dil is put on cold it should make the car very cold after several miles. If it is working, I think you will notice the drop in tempreture.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Well i have a leak passenger side as well so it must be catching mine is rad though but cant find where its leaking from and i'm losing some water from header and i have a wet patch under drivers side front,water feels oily so its deffo Rad
    Irmscher Insignia CDTI 130
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. Air con radiator
    By sebadee in forum Vectra C / Signum Troubleshooting
    Last Post: 27th September 2011, 20:33
  3. radiator how to?
    By steve1412 in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:21
  4. Radiator on 3.2 GSI
    By JJGSI32 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2011, 22:18
  5. Radiator
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 11th February 2009, 22:04
