Thread: Flat blade smear
    Jul 2009
    The Rift, Cardiff
    Default Flat blade smear
    Fitted flat blade wipers today because my old ones smeared like mad, the new one works great wiping up but when it comes back down it smears quite bad! I've tried sliding the blade out from the spoiler and putting it back in the other way but its still the same. Is it just because they're cheap tesco ones or maybe the angle of the blade on the screen?
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    did it smear in the same place with the old wipers?
    have you used anything like rainx?
    my advice would be that its not the wipers at fault, you may have some contamination on the part of the screen where it smears. give it a good clean with a good quality screen cleaner or methylated spirit, plus give the blades a wipe with some meths too, to remove any mould release agent that may still be on the rubber blades.
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    When it comes to wipers, I believe you get what you pay for. My Bosch Aero flatties work a treat.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    get bosch ones , there expensive but worth it
    Dunstable
    Even though they're cheap ones, they should still do the job..if they're no good, I'd take them back..I've used cheap flatblades and still do and have never had a problem
    Regular Member badback's Avatar
    Runcorn
    I've tried 2 sets of the cheap ones, both were poo, so I've now got the Bosch ones, much better. £25 inc p+p.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    they are expensive but what can you do as above cheap cause trouble
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    i got a set of gm ones from the dealer think they were about £30 and what a load of crap they are i will be going back to standard ones soon
  1. Rear Flat Blade?
    By victorM in forum Bodywork & Interior
    Last Post: 17th October 2009, 15:28
  2. Flat Blade Wipers
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 13:17
  3. GM Flat Blade Wipers
    By Mark The Cabby in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2007, 20:00
