Thread: any idea what the problem is???
    Jan 2010
    caithness
    Default any idea what the problem is???
    well 2 problems
    1.... water getting into passenger footwell after washing car . where is it likely to be coming from
    2.... finding it a bit stiff when changing into first and third gear any ideas?
    for any one willing to help its an 02 vectra 2.2sxi,
    1.. clutch seems fine
    2.. door seals look ok
    thanks in advance for any help :-)
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    common 1 is pollon filter , the drain hole is prob blocked with dirt and leaves
    sorry cant help on number 2
    Jan 2010
    caithness
    Quote Originally Posted by chris1804 View Post
    thats a good point i noticed there was soap and water building up below windscreen. didnt put two and two together. now i hope its just a case of finding, and poking into drain hole,,
    thanks chris
    Regular Member signumturbo04's Avatar
    SCOTLAND
    depending on what gearbox it is the f40 boxes were bad for gears being sticky or awkward to get into gear, vauxhall solved the problem on mine by draining out over 3 litres and refilling with 2 and a half, (sorted mine)
    Oct 2009
    Sandwell
    Quote Originally Posted by bbb69 View Post
    thanks chris
    open the bonnet and ake the rubber seal off open the panel up and you will see your pollen filter just use somat to poke the drain hole, hope this helps there is a how 2 on here i think
    Jan 2010
    caithness
    due a service soon im hoping i just need a wee top up
    Sunerland
    the drain hole is just to the right of the pollen filter, check that your filter is ok if wet replace, also check to see if your heater is working properly, this water ingress can cause you heater fan to not work on number 1,2,and 3 but works on 4 . If your lucky you might of caught it in time.
    HTH
    Steve.
    Jan 2010
    caithness
    heater is fine on all settings ....thanks for all the help
    Regular Member old cruiser's Avatar
    slough
    To be honest mate if you're thinking of gearbox being topped up , I guarantee they won't do it as part of the service, they never seem to check these things!! might be worth specifically asking them to do , also your problem might be down to the linkage at the gear lever where the joints may be dry and need lubing.
    Cheers Pete
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Clutch blend at the stealers will sort the gears.
  1. Good idea / Bad idea......?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2009, 09:09
  2. Anyone Have Any Idea What This Is?
    By AntB in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2008, 15:04
  3. superchip good idea or bad idea
    By lewrymyster in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 19:14
  4. superchip good idea or bad idea
    Last Post: 26th June 2008, 19:09
