Thread: Tailgate removal ??
    Jan 2010
    Coventry
    Default Tailgate removal ??
    Hi all, going to change my tailgate cos of a dent. Has anyone done it, those pins look hard to get at ? Can the pins be re-used ?
    Thank in advance, Jayson
    p.s. Nothing found on "search", honest
    Sunny Dartmoor
    I think bish as replaced his recently,might be worth sending him a pm........
    Jan 2010
    Coventry
    Quote Originally Posted by glenboy View Post
    Ok, cheers mate.
    Jan 2010
    Coventry
    No answer from bish. Do the pins tap out, if so which way, or un-screw ?
    shouldnt need to knock the pins out , the bracket should be in 2 parts and the pin is the swivel point
    they should be bolted to the roof under the head lining so should only need to undo a few bolts and disconnect the electrical harness and vola , roberts your mothers brother
    Professional Trader
    sheffield
    Dont undo the bolts under the headlining, dissconect the wireing plug in the rear fusebox, then take the plug off, as this wont fit through the hole, then feed wire up,then take off the boot struts, (make sure someone is holding up the tailgate or you will be asleep in the boot) then take the little clips off the pins and knock the pins out, you will see which way to knock them out, they only go one way....job done.....
    Jan 2010
    Coventry
    Cheers fellas. Roll on Saturday then.
    Jayson.
  1. Tailgate , removal ?
    By biffbangpow in forum Bodywork & Interior
    Last Post: 2nd November 2012, 18:50
  2. tailgate interior trim panel removal
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 5th June 2012, 17:50
  3. Tailgate strut removal?
    By rushy in forum Bodywork & Interior
    Last Post: 9th December 2011, 09:19
  4. tailgate removal vectra c
    By marts cdti in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 23:45
  5. Estate tailgate interior trim removal
    By parapaul in forum Bodywork & Interior
    Last Post: 27th December 2006, 14:24
vectra c tailgate removal
remove vectra boot pins
vauxhall vectra tailgate wiring removal
unplug vectra c tailgate wire
