very nice job, my saab diesel has twin exhausts but they are downturned and hidden by the valance. Much prefer your look.
Warranty no, as the exhaust only carries a 12 month warranty anyway. But the new exhaust silencer and Irmscher Y piece carry a 12 month guarantee in theri own right anyway.
Performance will have no negative effects. If anything it will run a little smoother as the system is a little less restrictive. Irmscher will have done their homework on the flow when they designed the Y peice and would not be allowed to do it if performance was effected. The MY2011 Insignia Twin Turbo Diesel will also have a twin exit exhaust.
I have now done 800 miles since it was done as MPG is not effected, it runs a little better. I did the same to my last two 1.9's and they were fine. If fact the Signum when done back to back on the rolling road at Northampton RR saw 156bhp and 248lb/ft.
Which Saab have you got, I thought the only diesel with twin exhaust was the 180PS AERO TTiD, and they are exposed?
Warranty on the engine I was thinking because compression & back pressure having changed can it be a way out for Vauxhall if there is engine problems.
Amos
Is the 'Y' piece the same as the Vectra one, someone has one for sale on the forum and I was wondering if they are the same part number.
Mav, you know when you say use the 2ltr Turbo right side back box, do you know if the 'Y' piece from that model can also be used instead of the Irmscher one ??
Is the sleeve you mention to fit over the two sections that are to be joined together or is the 'y' piece slightly bigger than the back box pipe diameter so fits over it anyway ?
No you can't use the 2.0 Y section as they have a 1.75" diameter on both sides. This would severely restrict the engine.
The Irmscher Y peice has the correct 2.0 CDTi diameter on the left hand side, which keeps things as they should, then the right hand side is sleeved down to match the 2.0T's 1.75".
You could argue that having 1.75" either side would work out the same as the single CDTi, but the 2.0T diamter is smaller on the centre section, so you would get a major restriction BEFORE the pipe splits either side.
Get the Irmscher Y peice, £120 sounds alot, but it's designed for the diesel and you get the exhaust hanger with it which retails at about £37 from Vauxhall on it's own.
Hi Mav,
I am new to this site and would appreciate your assistant in attaining the total cost of the Right hand box, Bumper trim and where to source these parts (I understand the Y peice inc.Sliencer hanging bracket is £120).
Any indication as to the labour costs involved, as I too have a Insignia 160 SRI.
Many thanks
Ardren
