Thread: egr fault ?
    grimsby
    Default egr fault ?
    hi got fault code p0400 egr flow malfunction .taken it off and cleaned all the gunk out .refit egr valve canceled fault code and run engine up.two mins later same fault code again what do you think i should do next?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    When you cleaned it how did you clean it? - by removing the solenoid and getting rid of the corrosion in it?
    The EGR valve I found that when I cleaned this it unmasked a hidden fault.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    grimsby
    did not clean inside the solenoid the valve move freely is this easy to do
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by learoy69 View Post
    do a search m8 its some where or in the How2
    Gazza4
    grimsby
    had a look at the how to the centre pin of the solenoid in my egr valve is almost level but the 0nes in the how to after clean look alot further out is this correct
  1. Not sure if this a fault or not.............
    By carperjake in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 20:39
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. ABS fault...
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2011, 03:05
  4. Another Fault
    By khile in forum Troubleshooting
    Last Post: 20th March 2010, 18:57
  5. swirl valve fault or egr valve fault
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 09:04
