Results 1 to 2 of 2
Thread: Coolant Lamp
    Regular Member ZC_74's Avatar
    Dec 2005
    Australia
    Default Coolant Lamp
    Guys
    In the window where it shows what gear you are in (auto) there is now an icon there which, when I looked in the book, is the low coolant signal.
    I've checked the coolant bottle and it seems about half full. So questions are:
    1. Is the lamp right and I need to fill it up?
    2. If it needs filling up what is the right fluid to use because if I go back to the dealer they will charge me 10x what I can but aftermarket
    3. Is the signal faulty?
    4. If it is faulty can I reset it or is it something only purely done at the dealer.
    Regular Member Inspektor's Avatar
    Northampton (Santa pod)
    Had the same on mine, 2.0dti manual. It was not low when checked under the bonnet but some corners or long bends such as M25/M40 junction it would come on and stay on. With the car on a flat surface I topped it up to the max level line and it's been fine since
  1. Fog Lamp
    By robdd1 in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2012, 17:52
  2. Fog Lamp Bulb..I am right in saying....
    By JB007 in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2011, 15:14
  3. fog lamp
    By damman33 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 20:40
