Results 1 to 3 of 3
Thread: stored fault code
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    Default stored fault code
    hi guys ive had the spanner through the car light up on my dash, its only there while its in ignition and it goes when i start the car. it happened after i took the key out of the fob and turned the ignition on with just the key without the fob. Is there a quick fix that i can do myself to get rid of this stored fault code or will i need the diagnostic machine to clear it.
    Cheers guys
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Make sure you have things like radio code, etc then it's safe enough to disconnect the battery for around an hour. With luck that should reset the ECUs. Should the fault still be present when you subsequently reconnect and start up, then the fault light will illuminate once more.
    The more useful remedy would involve reading the code and determining the cause - then eliminating it. However you can determine the practicality of that one.
    11 Post(s)
    Quote Originally Posted by vectrasri-j View Post
    It'll clear itself after certain number of clean starts / weeks. Mine took 28 days for it to clear, other people have said their's went after 30 or 60 clean starts.
    By clean starts, I mean no current faults that will continue to get logged in the ECU memory.
  1. Fault code
    By rob2.0t in forum Engine & Drivetrain
    Last Post: 21st November 2012, 22:34
  2. Fault Code Help
    By rmg1 in forum Y & Z30DT Specific
    Last Post: 3rd October 2012, 21:12
  3. fault code on vec c 1.8 sri please help
    By gavs-sri in forum Engine & Drivetrain
    Last Post: 10th April 2012, 21:52
  4. how do you know if the code is stored
    By craig2.2 in forum Engine & Drivetrain
    Last Post: 25th June 2009, 20:01
  5. Stored Fault Codes
    By parapaul in forum Engine & Drivetrain
    Last Post: 11th July 2008, 12:41
