Thread: disable egr 1.9
    southampton
    Default disable egr 1.9
    can anyone help can i disable the egr on my 1.9 signum using op-com have cleaned the the thing out performance has improved but still slugish below 2000 rpm or is it to be a new egr ?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Nobody has found a way to disable it other than as an extra feature on the Regal remap - try the Fiat gasket mod
    southampton
    thanks for the reply i think its going to be a new egr can you blank it off ?
    Mar 2007
    Southport
    No but you can partially blank it off using the modified Fiat gasket, it has 4 small holes in it as opposed to one huge square hole
    southampton
    i think i will try the fiat part thanks for the advice
    southampton
    will fitting the fiat gasket cause my dpf to fail ?
    Mar 2007
    Southport
    It shouldn't make any difference to the dpf & will just reduce the amount of dirty exhaust gases going through the egr & inlet manifold
    The Fiat Part No is:- 55225287
    southampton
    thanks will order gasket from fiat will let you know how i get on
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    You can blank it off altogether but you will get the engine light on and that's all!. No limp home mode, no problems whatsoever actually.
    I did mine about 1100 miles ago and the car runs great, turbo spools quicker and the car pulls much better from low revs, fuel economy unchanged, maybe a tiny bit better, but I now get no soot in the inlet manifold which can only be a good thing.
    The error code is 0400 EGR gas flow. I still check regularly if there is anything else logged, but no nothing more.
    Since the EML is in the bottom right corner of the dash, it's hardly noticeable so if you can live with a small yellow light on the dash, then go for it and blank the egr off altogether.
    Jul 2006
    Wolverhampton
    Just a quick update, it is now over a month since the previous post and about 3000 miles since I blanked my EGR off all together.
    The car runs perfectly, pulls well, no flat spots, economy is well, currently 50.5 mpg from a remmaped 1.9 that goes like stink, so no problems there, starts fine, idles fine, no problems or glitches whatsoever, just the little yellow engine symbol due to fault code P0400 EGR gas flow which does not cause any sort of limp home mode.
    So if you don't mind a little yellow light, then blank it off altogether and never suffer sooted up swirl valves.
  1. Disable alarm?
    By TimK in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2012, 00:33
  2. egr disable 2L ??
    By dc6839 in forum Engine & Drivetrain
    Last Post: 22nd July 2011, 10:51
  3. disable egr with op com
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 3rd February 2010, 20:13
  4. Possible to disable ABS?
    By MarkySparky in forum Suspension, Wheels & Brakes
    Last Post: 24th December 2009, 02:06
