when my cars under hard accelaration is seems to lose power and goes into what i found to be called limp home mode but a simple switch off and on again allows car to return to normal
i have a spanner light on dash what are usualy couses?
thanks
thanks
It sounds like your EGR valve is blocked to me. I suggest you check out the EGR maintetnace threads as this will likely lead you to the solution and show you how to remove, clean and re-assemble the valve.
ok where is it located on 1.9 cdti engine
there's a how 2 for cleaning the EGR, and you could type in EGR in the search button, there's plenty of threads regarding this problem.
Hi mate try this link and dont forget the boost sencor too. HTH
http://www.vectra-c.com/forum/showthread.php?t=39441
This tells you where to find it, do a searth for cleaning it properly which involves drilling a 3mm hole in the top to get the solinoid out.
Steve.
Hi,
I had the same problem. I took it to a garage with diagnostic equipment. It was just a bit of split pipe, which he replaced in a minute and my cars been good as new ever since. Totally felt the different as soon as I pulled away. Sorry not sure which pipe though.
