Thread: spanner light
    Jan 2010
    Dewsbury
    Trim : sri
    Engine : z28net
    Default spanner light
    when my cars under hard accelaration is seems to lose power and goes into what i found to be called limp home mode but a simple switch off and on again allows car to return to normal
    i have a spanner light on dash what are usualy couses?
    thanks
    Swindon
    It sounds like your EGR valve is blocked to me. I suggest you check out the EGR maintetnace threads as this will likely lead you to the solution and show you how to remove, clean and re-assemble the valve.
    Jan 2010
    Dewsbury
    Trim : sri
    Engine : z28net
    ok where is it located on 1.9 cdti engine
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    there's a how 2 for cleaning the EGR, and you could type in EGR in the search button, there's plenty of threads regarding this problem.
    Sunerland
    Hi mate try this link and dont forget the boost sencor too. HTH
    http://www.vectra-c.com/forum/showthread.php?t=39441
    This tells you where to find it, do a searth for cleaning it properly which involves drilling a 3mm hole in the top to get the solinoid out.
    Steve.
    dURHAM
    Hi,
    I had the same problem. I took it to a garage with diagnostic equipment. It was just a bit of split pipe, which he replaced in a minute and my cars been good as new ever since. Totally felt the different as soon as I pulled away. Sorry not sure which pipe though.
    By Shadrack in forum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
