Results 1 to 10 of 21
Thread: Dashboard lights and clocks all switching off
    Swindon
    Default Dashboard lights and clocks all switching off
    My signum 1.9CDTI 120 keeps shutting the dashborad lights and clocks down leaving me with no rev counter, speedometer, fuel or temp guages. In most cases, switching off, removing the key and restarting has brought everything back to life. However, even that little trick has been unsuccessful in bringing the dashboard back to life this afternoon!
    Has anyone else had this problem, or know of the route cause of the problem and the necessary resolve?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Im posting this from my phone at the moment mate so this will be swift. Its either going to be the CIM or ABS plug, first is a 400 quid dealer fix and second is free. Go into advanced search, put my name in and the words abs plug and you should find some more info with pics.
    leicester
    I have the same problem and i have been given different problems from different mechanics and i am really confused. Are you sure its the ABS plug and what do i actually clean on the ABS plug?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Moosa786 View Post
    The ABS plug is only the first stop mate as you can check it for free, but from previous posters the some of the same code's get thrown up with the dodgy ABS plug and the CIM.
    Pull the bit marked in red and the plug will lift off, then its just a case of giving the contacts a squirt of contact cleaner or wd40, but be sure to clean up any moisture.
    leicester
    Ok i will try that on monday when i return home as i am away for the weekend. I was told by a local mechanic that its a EGR valve does that ring any bells it dont make sense to me as the EGR is to do with the emission etc but am not a mechanic so i cant be to sure :S
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No mate, all the EGR does is let some exhaust gasses back into the intake to re burn. It has nothing to do with the dash electrics.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Rushy is correct with his diagnosis...
    ABS plug is the first port of call as it is simple and free to look at and clean if necessary, however this is usually for the older vehicles...say upto 2005
    2nd, check fuses in the Fuse panel on passenger end of dash.
    These are F1 - Infotainment and transport mode(?)
    F7 or F17, and F9 or F19 - BCM power feed
    F4 Accessory..not on all cars
    F10 CIM module power
    F12 BCM power overload fuse.
    Finally have a check done on the CIM module...
    If it is the CIM module, loss of instruments is often accompanied with a spurious loss of indicators, cruise control...
    As said above, very expensive as replacement and programming into your car is the only proper fix.
    leicester
    I cleaned the ABS plug and its still bringing the same problem i will try the 2nd options as Robsey has said. If it is the CIM module where is it located and what is the costs of replacement so i can keep in mind.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Right, the CIM module is wrapped around the steering collumn, right up behind the steering wheel.
    The ignition switch that you put your key into is part of the assembly that makes up the CIM module.
    Replacement cost varies upon spec etc, and whether the fitter got it wet last night / or not..sorry sounds flippant but the dealer prices do vary.
    Cost of CIM = £180 to £350
    Fitting and programming will bring full cost to between £300 and £500 !!
    leicester
    Ive tried both the options you advised me and still have the problem. the fuse panel is all working. So i guess its the CIM module, will the cost be between £300-£500 with parts and fitting?
  1. Paradise by the dashboard lights....
    By Jockweiler in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 16:56
  2. New clocks and footwell lights (pics)
    By Robbie69 in forum Electrical & ICE (including SatNav)
    Last Post: 26th August 2009, 11:39
  3. Dashboard Lights
    By acedaz in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2009, 22:57
  4. dashboard lights?? no manual :(
    By 04vectra in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd December 2007, 18:33
  5. Blue Dashboard Lights
    By FACUP76 in forum Styling
    Last Post: 22nd February 2006, 19:59
pairing new clocks to vectra c
connection between cim and speedo vectra c
Wheres the power steering fuse on vectra c site:www.vectra-c.com
