Thread: V6 3.0 CRTI Auto Signum tyre load
    Jul 2009
    SE
    Default V6 3.0 CRTI Auto Signum tyre load
    Hi all, seems there is a lot of confusion out there as to tyre load ratings for the V6 Signum (and Vectra). Mine has 91 rated tyres on the fronts and 95 rated on the rears.
    I need to replace the front 2 and about to press the button for 2 x Goodyear EfficientGrips but want to be sure I am doing the right thing in getting 95's all round. Has anyone got the definitive answer for this?
    On a similar topic the manual says tyre pressures with a load of 4 x people are 38 front and 35 rear. The interesting bit though is the tyre pressure for 'full load' (thought 4 x people is full load) which gives 41 front and 48 rear. This seems really high - so if I take the family plus holiday baggage then the idea is to bump it up to 41/48 for the journey? Does anyone do this (with a deflation in between journey home)?! Would hate to add 4 x new tyres (at close to £700) and to ruin them with wrong pressures!
    Thanks, Mike
    From memory, this is one of the cars that HAS to be on extra-load / XL / reinforced rated tyres
    These should be 95 (215/50R17) or 94 (225/45R17)
    When using XL tyres the tyre pressures have to be higher, hence why they appear to be high values
    Follow the pressures in the hand book, thats what it is for.
    M8 is right, you need XL rated tyres on an auto 3.0 cdti.
    Jul 2009
    SE
    Thanks guys, 95 rating it is then. Best price I have seen is for the Goodyears via KwikFit for £130 odd each. Decision is 2 or 4 (they will all need doing soonish)! Painful...
    Have a look here mate - http://www.camskill.co.uk/products.php?plid=m54b0s16p0
    You would need to get them fitted but its a lot cheaper than you have just put at £130 each.
    Yes, 225/45/17 will fit with no adjustments really needed.
    Regular Member themarbleman's Avatar
    sussex
    Default Tyre Pressures
    I have the 3.0 V6 CDTi
    Tyres 215/50/17 V91.Eagle NCT's
    Fronts are inflated to 41psi
    Rears are inflated to 38 psi
    Perfect wear acroos the whole tyre tread and i get around 19-20k
    out of them..
    Hope this helps...
    France
    As far as I remember, 3.0 V6 auto should have at least W rated tyres, 91.
    Quote Originally Posted by littlejohn View Post
    The EU conformity, as is the same for all Vectra, is actually only H rated tyres
    Personally, there is no way I would use that
    However, you can run with V rated tyres quite safely, but most people use at least W rated
    I am currently using Y rated tyres, as they are cheaper!
    I have also tested sets of ZR and Z rated, all work as expected
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    I wouldn't use H rated either Maximum speed rating is exceeded by the majority of UK Vectra 'C's. 'W' rating seems to be standard factory-fit, and I have been advised that some insurers would not be happy with 'V' rated tyres, although I did use them on my old 2.0T, as their maximum speed rating is 149mph.
    Quote Originally Posted by john_k_sri View Post
    Pretty tough if they are "not happy", just present the vehicles EU Conformity Certificate
    It clearly states "tyre : 205/55R16 H 89"
    Even with the basic settings from the handbook, the lowest tyre I can find is a 205/55R16 with 91H
  1. Tyre load rating
    By Threepiers in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 21:18
  2. tyre load index
    By starykokot in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2011, 21:26
  3. Tyre load ratings.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2010, 00:22
  4. Tyre load index
    By Roadhog in forum Handling & Braking
    Last Post: 28th April 2009, 09:53
  5. tyre load calculator
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2009, 08:20
signum extra load suspension
