Results 1 to 10 of 22
Thread: Clicking noise when turning the heater dial
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Clicking noise when turning the heater dial
    OK - so when I turn my heater dial to the furthest heat or cool settings, I get a click click click coming from the dash.
    It doesn't do it when you vary the temp dial a little - only when going either FULL cold or FULL hot.
    The mixer flap is working as it does vary from cold to hot as it should..
    Any ideas on what the clicking is and how to fix?
    A
    Mileage : 000
    Sounds like one of the teeth has broken off the motor. It is quite common for this to happen on the "recirc" motor too.
    Middlesex
    Trim : SRI
    Mileage : 100k
    OK - is that an easy / cheap fix - or not?
    Mileage : 000
    When I changed the "recirc" motor it cost about £60 trade. Fitting it was a bit of a pig. But it all depends which one of yours might have gone, and where it is situated. If you do a search for "recirc" motr, you should find some threads. There is one with a photo of the place where it is fitted. It might have show you the other motors too, if they were "in the shot".
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    go to a smashers!, i got 1 from a nearly new motor was about £10, its a bit fiddly and is located up the left side of the heater box! i think i have a pic!!. it has a broken tooth!, ill try to put a better one of the whole thing.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    This is it , its held in place a an angle so may look slightly different, they can be took apart easily as mine shows the common problem!, easy fix if you can get plastic cogs.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Mines doing the same also on Recirc Now too
    Middlesex
    Trim : SRI
    Mileage : 100k
    OK - so does that unit control recirc and heat distribution etc etc all in one? The recirc button operates fine.
    How actually do you get too it?
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    No, I think there are three separate ones: recirculation, heat distribution & vent options. IIRC, the recirc one is the easiest to get to, and that's a a pita, I've heard it's a dash out job for the other two.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If yours clicks with the hot/cold dial this is your prob as above, take out the glovebox and you have to pull down the footwell cover, and its located up on the side of the heater box, you will see a RED arm connected to it.
  1. Heater clicking noise again
    By Bamber in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd July 2012, 22:40
  2. Weird clicking noise from heater control or glove box
    By rollercoaster63 in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2011, 14:29
  3. Temp dial not working/clicking behind dash?
    By Terry Tibbs in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 18:12
  4. clicking noise (assuming behind heater control pannel)
    By 9tjc in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2009, 23:11
  5. Clicking noise only when turning ignition
    By mbonnick in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2007, 07:10
vectra c heater clicking
vectra c clicking noise from heater
https:www.vectra-c.comforumshowthread.php105649-Clicking-noise-when-turning-the-heater-dial
vectra heater control clicking when srarting vauxhall vectra heater clicking noise06 vectra heater makes clicking nosevectra heater clickingvauxhall vectra c heater clicking2005 vectra tdci loads of clicking from dashboard when i turn ignition onwhy does my heating dial click vauxhall vectra heater clicking whats the problemvectra c clunk when turn heater to coldvauxhall vectra clicking noisevauxhall vectra air con clicking sound when on coldvectra c clicking noiseclicking noise coming from my vauxhall vectra c behind the heating controlsClicking noise when turning from cool air to heat in carvectra c heater making noisevauxhall vectra estate clicking noisevauxhall zafira heater noiseastra ticking noise behind dashclicking noise from heaters in nissan qashqai carclicking noise coming from Vectra heater vectra 1.9 cdti heater clickvectra c ac controller clicking
