Results 1 to 10 of 13
Thread: I Need to follow a fuel tanker
    Ayrshire
    Default I Need to follow a fuel tanker
    Still Averaging 24mpg even after long runs
    The car is a 2.2 direct (not the most ecenomical engine) but i have read post on here that most people are averaging 33 - 36 mpg.
    The emmisions light is on and Had the scanner on the car and is showing
    p0136 02 sensor circuit malfunction (bank 1 sensor 2)
    Firstly am i right in thinking the 2nd sensor would not effect fueling etc as its main role is to check the condition of the cat.
    What other things would you reccomend that may be causing such low mpg, there is notecable flast spots from 1200 - 2500 rpm
    I will be replacing filter and plugs...is there anything else that i could be looking at, would cleaning the egr make any difference
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I'm pretty sure there is a precat on the 2.2 (don't know that much about them though) The second sensor would be after the pre-cat but before the main cat. If its giving false readings the car may well be overfueling thus the poor fuel economy
    Ayrshire
    Thanks for the reply john, i dont think there is a pre cat, had the car on the ramp at work and noticed lambda 1 at the manifold, cat at the down pipe then sensor 2 then a small silencer.
    maybe the non direct has the pre cat
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Ok after doing a bit of looking you are right, however the O2 sensors are there to control fueling so that is where I would start especially as that is one of your faults
    Ayrshire
    Thats great john will be replacing tomorrow anyway, £75 from Partco...seems ok
    Next things to do is replace air filter and plugs, clean egr and try this airbox mod thing that everyone keeps mentioning worth a go
    Mileage : 000
    What about the coolant tempreture sensor. It might be telling the ECU it is still cold, so it might be over fueling.??
    I'm on 35 ampg at present hth ...............................
    Regular Member noel.nev's Avatar
    Pen-Y-Bryn S.Wales
    would the how to on egr cleaning for the diesel be the same for the 2.2 direct because im only getting low 20s too
    Ayrshire
    Quote Originally Posted by Tadpole View Post
    Thats it rub it in.....
    Regular Member ballan22direct's Avatar
    isle of lewis
    I only get about 26mpg that all town driving.
  1. follow up from last thread
    By ladyvec in forum Engine & Drivetrain
    Last Post: 14th December 2011, 13:16
  2. Anyone fancy helping me rob a fuel tanker?
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2009, 21:10
  3. Oil tanker hijack..
    By macdad in forum General Chat
    Last Post: 18th November 2008, 02:08
  4. Formula 1, does anyone else follow it ?
    By simac in forum General Chat
    Last Post: 22nd September 2006, 03:45
