Thread: Clock/Trip Meters Not Holding Values
    Regular Member DanR's Avatar
    Hampshire
    Vehicle : Insignia 2.0 CDTI Ecoflex
    Trim : Elite Nav
    Engine : A20DTH
    Default Clock/Trip Meters Not Holding Values
    Hi Guys,
    Finally collected my Veccy yesterday and I haven't stopped grinning like an idiot .
    However, there's two minor niggles and I thought I'd ask here before ringing the dealer;
    Firstly when I switch the ignition off the rev counter, temperature & fuel gauges freeze where they are until I next start the car, whereupon they return to zero and then climb back to the proper values.
    Secondly when I switch off the ignition for more than a minute or two the clock and trip meter on the dash all reset to zero, the trip counters on the BC all reset to zero except the fuel consumption which holds its value.
    I have to admit that I'm a little stumped so if you guys can suggest anything I'd very much appreciate it!
    Dan
    Full Member Robsey's Avatar
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    Sounds like you have a BCM module problem here, or perhaps a CIM module fault.
    I say this, as the CIM transfers all BC data from the main ECU to the low-speed canbus sysTEM.
    The CIM also controls the dashboard functions...mileage etc.
    The BCM on the other hand controls the main display including the BC screen.
    Firstly,have a good look at the fuse board at the end of the dash.
    Have a check of fuse 1 (delivery mode fuse for infotainment system), fuse 12 (overload preotection and relay), and then fuses 7 and 9 or 17 and 19 for the remainder of the BCM functions.
    That then leaves fuse 10, for cim module power and fuse 4 for accessories.
    If these are all intact, then return the car to the dealer.
    However firstly consider the following "normal" functions of the dash and instruments
    regarding the consumption figure, dependent upon engine, it will always reset to one figure...possibly about 38 mpg....nearer to 28 for the bigger petrol engines.
    The needles etc should fall to zero or minimum marks immediately, however the trip figure and odometer figure on the dash should remain illuminated for about 20 - 30 seconds after you turn off the engine, open a door, or unlock the car....otherwords whenever the interior lighting is illuminated.
    Everything should extinguish after this length of time, or when you lock the doors.
    Hampshire
    Trim : Elite Nav
    Engine : A20DTH
    Once again you are a star Rob!
    I'll check the fuses and failing that have a word with the dealer.
    Regarding the trip meter and distances/averages on the BC I assume that these are supposed to hold values when the ignition has been switched off?
    Dan
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by DanR View Post
    Yep, all four sets of values should be retained, until you do a reset, for both BC1 and BC2 regardless of whether your turn the ignition off or not.
    I did toy with the idea, that the screen may be missing one of it's browns or reds...but before messing, let the dealer have a look.
  1. How many meters of cable???
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2011, 22:34
  2. Gas Electric Smart Meters..??
    By macdad in forum General Chat
    Last Post: 14th January 2011, 22:45
  3. pre-paid leccy & gas meters
    By Big Knox in forum The 'Off Topic' room
    Last Post: 26th November 2009, 18:08
  4. Used Car Values - Good News!!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2009, 17:19
  5. No meters/feet with satnav voice after fw upgrade cd70
    By Peabrain in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:19
