Thread: high fuel pressure cdti 150
    Regular Member kamar's Avatar
    bradford
    Default high fuel pressure cdti 150
    hi guys did a search but cant find much anyone know what will cause high fuel pressure on the cdti 150 an what are the effects or simptoms and how do i get this sorted
    Boldon
    what makes you think the fuel pressure is high? fault codes?
    Full Member Big Sig's Avatar
    From a previous post he has had fault codes. IMO you need to tech 2 it to see what is actually wrong. It could just be a sensor.
    bradford
    it had a fault code p0090 rail pressure control solonoid valve circuit range/performance poss diviation, i did put a post up but not much info... sorry what is tech 2 as im not aware and who or how can i get it checked
    Cambridgeshire
    Quote Originally Posted by kamar View Post
    You need to take it to your local Vauxhall dealer and ask for it to be Tech2'd and they will stick a machine on it to find out exactly what the problem is and where it is usually. From that they should be able to tell you what will be needed to fix the problem.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    as above your wasting your time, it need hookin up to the tech2 or op-com.
    bradford
    how much shoud dealers charge or do they all varie any ideas of simptoms that it will cause......
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    about £50 m8
    Gazza4
    bradford
    thanks iyl see if i get a discount for some reason my dealers decided to give me timing belt kit for £90 inc vat and £58 front discs and pads.lol
  1. High Pressure Fuel Pump
    By trevteah in forum Engine & Drivetrain
    Last Post: 9th October 2010, 19:09
  2. air con and high pressure fuel pump
    By dayna1501 in forum Introduce yourself.
    Last Post: 23rd June 2009, 18:52
  3. High pressure fuel pump
    By dougiemc in forum Engine & Drivetrain
    Last Post: 3rd May 2009, 21:32
  4. High Pressure Fuel Pump
    By nesbigr0 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 17:08
vauxhall cdti high fuel pressure
what should the fuel pressure be on a vectra cdti
insignia high fuel pressure problem
