Thread: radio
    Jan 2010
    Dewsbury
    Trim : sri
    Engine : z28net
    Default radio
    my cxar battery just went flat and now its back on it shows 4 safe and i carnt get it into program mode to enter code any ideas?
    thanks
    Mar 2007
    North East
    Hold the AS button and turn the key to position 1, the radio should beep and show something like 10 safe.
    Use the 1-4 buttons to enter the code and then press AS till the radio beeps.
    eg for a code of 4321 you need to press button 1 four times, 2 three times, 3 twice and 4 once.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yep..just as he describes it
    Jan 2010
    Dewsbury
    Trim : sri
    Engine : z28net
    tried it and nothing just shows 4 Safe
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    The code has been entered wrongly a few times (4 times).
    What you need to do is leave the radio switched on...for ages, and then after a period the display will change to CODE or 4 - - - - or some digit followed by - - - -.
    When this appears, you can then enter the code again.
    This time varies from 1 minute, upto 21 hours, dependent upon howmany times it has been entered wrong...the time doubles after each failed input.
    If the code does not work, then you have the wrong code for the radio...it may have been swapped at some time in the past.
    11 Post(s)
    If it's really showing 4 SAFE then you'll have to wait 160 mins. (2 hrs 40 mins) before you can enter the code. During that wait time you'll have to leave the key in the ignition (turned to position 1) and also leave the stereo on.
    See http://www.vectra-c.com/forum/showthread.php?p=1081781 for further info.
  1. CDC 40 radio
    By dave b in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2012, 23:20
  2. Radio 1
    By vec-cal in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2010, 00:17
  3. my radio
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 21:29
  4. CD 30 Radio
    By Stevel in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 13th July 2008, 17:15
