Results 1 to 2 of 2
Thread: Power Steering Cut Out
    Brechin
    Default Power Steering Cut Out
    Got a 2.0T which seemed to be running a little low on rpm over the past couple of days, just doesnt feel right idling (a little vibration through the car at idle) today started up as normall still the vibration, trouble free drive to work. Went for lunch ps steering light on and NO power steering at all , parked, switched off and on and steering normal again, is something on its way out??? Help please!!!
    May 2006
    Mansfield
    I had this when my battery was on the way out, the power steering is driven by an electric pump which takes a lot of current, if there is insufficeint voltage then the control unit cuts out the steering pump. It may be that if you are experiencing low revs the alternator is not charging the battery sufficiently after starting.
    SJ
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
