Results 1 to 10 of 19
Thread: Which one of these is AirCon refill?
    Regular Member danlat1415's Avatar
    Lancashire
    Question Which one of these is AirCon refill?
    I mentioned earlier that I was going to refill my Air Conditioning coolant. I've bought a refill with guage, and I'm supposed to connect to the LOW PRESSURE PIPE of the air-con.
    I've just fitted a K&N air filter, so I took this picture.
    Which one of these is the LOW PRESSURE PIPE?
    A or B
    A is quite a thick pipe.
    B is a thin pipe.
    [Ex]Admin Duncan's Avatar
    Pipe A looks like Low Pressure to me. Which engine is yours? - just so I can double check on TIS.
    Lancashire
    It's the 1.8 SXi - 52 plate
    Yep, definitely Pipe A as per your diagram. Your car needs 730g of refrigerant. Be careful though - since you don't know how much is still in there, it's going to be very easy to overfill and you won't know. Last thing you want is any stuff squirting out if it overfills!
    Lancashire
    hopefully that won't happen, the refill kit has a guage which apparantly tell you how much you've got? hmm but wouldn't that go off pressure?
    Do you know what pressure it should be at? I know it's 730g theres a big sticker just under the bonnet with some info on.
    Quote Originally Posted by danlat1415
    I've got no idea what pressure, or how that canister works i.e. how it (if indeed it can) tells how much you've already got in the system.
    Regular Member Ian's Avatar
    York
    problem with pressure is its temperature dependant, whereas teh weight doesnt change. Depending on how temperature effects these recon gases may result in it never being possible to do with a pressure gauge?
    Good point!
    All refrigeration engineers use pressure guages to see what the system is doing..the refridgerant is charged in the liquid (by grammes) and gaseous phases..so the tiny aerosol with it's little guage will prob tell you if there is enough of the gaseous phase to let the system run again.. if it's low though, i'd still get it profesionally leak checked..
    Deffo pipe A for the low pressure side mate..
    ( info from my mate the commercial fridge engineer via text message..lol)
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You could always evacuate the system and then add the required amount. Keep weighing the refill can, until it has lost the right amount. Assuming no leakage of course.
  1. Aircon refill
    By GoldenWonder in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2012, 17:01
  2. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  3. a question about air-con refill
    By BIG NEIL in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2008, 09:54
  4. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
  5. How do I refill Air-Con gas?
    Last Post: 5th July 2006, 16:11
