Results 1 to 10 of 11
Thread: V6 CDTi Engine Shudder
    Staffordshire
    Default V6 CDTi Engine Shudder
    I would welcome any advice re: 3.0V6 CDTi with 30,000 miles. 55 Plate. Between 1400 and 2000 revs in any gear the engine feels as if is is missing it gives the effect of driving over cobbles. I have had the car 2 months it has spent 6 days in VX dealers they say they cannot find anything wrong and suggest I change my driving style to avoid that rev band. No codes showing up and after talking to VX they say it may be a characteristic of the vehicle. They have updated software on EMS and replaced a sensor which produced small improvement for a short time but now as bad as ever. I have a three year dealeship warranty but that is not much good if they say there is nothing wrong. HELP!!!!!!
    Full Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Maybe it would be a good idea to check out this thread..
    Hope I can help you or leed you in some direction..
    http://www.vectra-c.com/forum/showthread.php?t=89265
    Mar 2007
    Beaconsfield, Bucks
    Mine did this too but mine was due to a 90% clogged fuel filter.
    Staffordshire
    Thanks guys I will bear in mind.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by marly View Post
    Damn ********! That's what my last V6CDTi did. Replaced the fuel filter and it was ok...but as I already bought the SCVs I replaced them too
    Staffordshire
    After hours of studying various comments on the Forum, I have now carried out the pedal test. I am getting code 0460. Does this make sense to anyone with the symtoms that my car is showing?
    Many Thanks
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    "P0460 Fuel Level Sensor Circuit Malfunction"
    is what I found on this site..
    2006 Opel Vectra C OPC Estate Arden Blue 255bhp Heated full leather Climate control Full powerflex rear suspension Power tailgate Retractable Towbar Eibach 30mm Original BBS RS-GT 2-piece forged 20" with 225/35 front and 255/30 rear HID 5000K Autolights Rainsensor Dim rearview mirror Heat reflective windscreen 280bhp airbox mode Tinted windows PDC
    You need to consult TIS to see what parts are affected by that fault code
    Sounds like the low pressure fuel pump is not receiving the right values
    When was the fuel filter last changed (recommended every 10K miles / 6 months, but the service schedule is 20K miles / 2 years)
    North Wales / Leeds / South France
    i have similar problem on my 54 plate has always done from 44k now with 78k, problem goes after a decent run in daylight, which makes you think the battery is furbar, not the case new battery new alternator pully and belt, tests giving right readings, any thoughts, lookking at getting SCVs just case !!!!!!!!!!!!!.
    34K miles is at least 2/3rd of the cars life!
    There is NO way I would have put up with it for that long...
    What age was the car when you first reported it at 44K miles, and where to?
    A blocked SCV will fail completely within about 5K miles, so I doubt it is that
    That suggests it is a faulty solenoid, as the car will run on the other five
    You really need to take the car to a diesel specialist, with experience of the Y30DT engine
    I will bet they can diagnose it within 30 minutes
  1. 1.9 cdti shudder and flashing service indicator, (misfire?)
    By GrannySmiff in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2013, 19:12
  2. Replies: 5
    Last Post: 25th January 2013, 17:44
  3. CDTI - Cold Shudder/wobble
    By Leemarksmith in forum Diesel Engine related
    Last Post: 10th December 2012, 18:43
  4. Shudder / egr
    By amir2300 in forum Engine & Drivetrain
    Last Post: 15th September 2011, 23:10
  5. VECTRA ELITE V6 CDTi Engine Shudder
    By trickydicky in forum Diesel Engine related
    Last Post: 22nd March 2010, 21:24
vectra c forum v6 cdti engine
