Thread: headlight's done in a fuse i think
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default headlight's done in a fuse i think
    Hi. Tonight i put my headlights on (aftermarket HID's) and the offside lit up then went out.
    I got home and swapped ballasts to no avail. I also checked the bulb by hooking it up to the nearside and it worked so its no fault of the HID kit.
    It appears that a fuse is blown. Can anyone help me find the offending fuse? Its a 2003 2.2dti.
    The manual i got with the car is for a facelift and there is only one mention of a headlight fuse. Iirc there should be one for left and right dip beams in most cars
    Many thanks
    Jan 2008
    Dundee
    UPDATE...
    on reading prevous threads, i think i might have tripped the module. how can this be reset? battery off?
    Jan 2008
    Dundee
    UPDATE... I know there are no replies to this but i have found the problem and i'm going to docoument this for anyone's future reference.
    The canceller capacitior from my HID's direct kit has failed causing the nearside lighting control module to trip. There is only one fuse on the headlight circuit which is a 10amp fuse 8 in the fuse box beside the battery. If anyone has similar problems and fuse 8 is fine the likelyhood is that one of the modules has tripped. Simply disconnect the battery for a few minutes and the module will reset itself and the circuit will re-gain power.
    Next a phone call to HID's direct as my kit is only three months old. Has anyone had to return a kit to them before? Your feedback is greatly appreciated.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Interesting one mate
    Jan 2008
    Dundee
    yes but now once again i have no damn headlights until i get a new kit
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Can't you fit your old bulbs bud?
    Jan 2008
    Dundee
    yeah i will have to. but will wait until i get in contact with hid's direct
    Regular Member no1baggiesfan's Avatar
    Jan 2008
    Newcastle
    Vehicle : 1.8 VVT SRi
    Thank you Keithy for that little bit of info.
    I have just fitted my HID kit and EXACTLY the same thing happened, removed canceller fitted just ballast and bulb to other side and hey presto, remove battery and HID's work perfectly, albiet without cancellers
    Cheers M8
  1. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  2. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  3. Preface headlight's
    By VECTRA_C_VIPSTYLE in forum Parts for sale
    Last Post: 25th July 2008, 19:38
  4. Which fuse?
    By Adam in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2007, 09:41
what fuse for headlights vectra c facelift
headlight fuse vectra c
headlight fuses vectrac
