Thread: whitch gear box does my car need
    hounslow
    Default whitch gear box does my car need
    hi ive got a vaxhall vectra 04 plate and the gearbox has basicly gone just wana know if any one knows which gearbox i need hayes nanual says its a f17 but on the internet its say a f18 so i am confused witch one i need and also like to know if the vectra b has the same gear box
    thanks ant
    Jan 2010
    kilmarnock
    The number that you need is undet the final drive unit look in from passangers wheel arch (wheel off) you will see a cover plate with 9 bolts in it the number is etched on this part it will look something like
    a341c34f1739
    the part in the middle (f17) defines type of gear box and the rest make up the ratio gear setting
    alhaw
    Regular Member DaveW555's Avatar
    Cannock
    or if you're feeling lazy just ring vx and ask them
    Regular Member benny's Avatar
    Feb 2006
    dudley
    what enigne do you have ? ...
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Whitch tools
    By marc vectra sri in forum General Chat
    Last Post: 4th June 2012, 20:56
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
