Thread: P1335 Fault Code?
    Hereford
    Default P1335 Fault Code?
    Hi Folks got a fault code of P1335, no rpm signal? (2L DTI Vectra 2002) Symtons are about five mins of starting the engine up the EM light comes on and the Rev counter drops to zero and the car goes into limp/ idle mode.
    This is intermiitent and if I floor the A/peddle it sometimes clears it. Any ideas
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    cranksensor fault had it before with a zafira
    Ashington, Northumberland
    Could be either crankshaft position sensor, or camshaft position sensor. They both throw up the same code. You may well get the following codes at the same time;
    P0400
    P0725
    P1651
    Hope that helps
    Hereford
    Default Thanks Guys
    Thanks guys, will take this one away and let you know how I get on, cheers
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. Vec-B 2.2 DTI SRI P0725 (D) and P1335 (A), HELP!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 11th January 2010, 22:51
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
2002 vauxhall vectra 1.9 p1335
Opel zafira error p1335
