Results 1 to 10 of 16
Thread: need some help please
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    Default need some help please
    ive just part exchanged my pre facelift vectra in for a facelift vectra 1.9cdti exterior pack and am looking to buy a vxr rear diffuser. vauxhall have quoted me £146 plus VAT. Looking at other threads, this seems a bit steep. Where else can i get it cheaper? and how does it fit onto the rear bumper - rivets? do you have to take the whole bumper off?
    im looking to get the V grille colour coded with the rest of the car. do i have to buy a new one ready primed or has anyone had theirs sanded, primed and re painted? has it worked?
    all advice is appreciated
    cheers
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Is it a vxr exhaust insert you are looking for? It should be about45-50 quid although not that easy to fit if you have the xp kit
    Nov 2009
    yeah, think so. its not the grille looking one. its smooth, with an exit each side. there's the red one that went on the black sri with the towbar somewhere in this section.
    Milton Keynes
    the grill can be done....
    http://www.vectra-c.com/forum/showth...our+code+grill
    looks good i think...think its a case of sanding it down with very high grit wet n dry, prime and paint? no doubt someone will correct me if i'm wrong!
    VX do the paint in spray cans so can get that from there..
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by george1987 View Post
    Yeah, thats the VXR Insert which is about £45 from Vauxhall - they have quoted you for the VXR rear valance instead.
    Nov 2009
    ive talked to a few garages/repair places and they say the only problem using the chrome grille already is that, after sanded, primed and painted, if it gets a cheap and water gets in, it could all flake off
    Nov 2009
    so, whats the difference then? i think thats me getting confused
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yeah thats the VXR insert part no.9271537
    With regards to painting the V, sand, plastic prime and then paint
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    You already have the rear lower diffuser (part of the xp kit). Thats the bit that runs around the whole of the lower bumper, the insert is the bit around the exhausts
    Nov 2009
    ive been quoted bout £60 for grille and £60 for the diffuser, just the painting etc and fitting. good or bad?
