Results 1 to 2 of 2
Thread: Indicator Bulb Blowing
    Regular Member Stuart_1985's Avatar
    Apr 2009
    Default Indicator Bulb Blowing
    About a month ago i had my front nearside indicator bulb blow, i have since replaced it with a brand new bulb but the dreaded "turn signal lamp" message appeared on my screen on the way to work, after checking it when i got to work it seems that the same bulb has gone again! is there anything i could check that could be causing it? could it just be the new bulb was faulty?
    Apr 2009
    Hi guys, just thought i would post up the answer to my own problem incase anybody else finds themselves in the same situation.
    After my indicator again stopped working i decided to investigate, below is the contact inside the nearside headlamp for the indicator bulb!!
    No wonder it wasnt working! i refitted the bulb holder but only turned it part of the way so the bulb is still making contact and has been fine since for a week and a bit, when i "click" the bulb holder into position the bulb doesnt work as obviously there is a bit missing.
    Can get one of these contacts from somewhere and just crimp it onto the cable the same was as the old one is? could i fill the missing bit with solder?
  1. N/S sidelight bulb repeatedly blowing - any thoughts why?
    By Barchettaman in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2012, 19:49
  2. Front indicator bulb
    By Mopar Man in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2011, 22:17
  3. indicator bulb
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2009, 18:57
  4. front Indicator bulb
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2009, 18:49
  5. o/s indicator bulb always on!
    By sebguy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2007, 00:34
