Thread: fault code
    wilts
    Default fault code
    hi all, im looking at buying a 03 vectra c sri dti, it has a few problems tho. it booted hard it goes into limp mode, ive read the codes and got...
    p1604 (loss of ipc serial data)
    p0100 (mass air flow sensor)
    p0400 (exhaust gas recirculation)
    thats what the code reader said the codes were. can anyone confirm them?
    will any of them make the car go into limp mode. it drives fine aslong as you dont really put your foot down.
    thanks in advance
    Regular Member ptrehearn152's Avatar
    norfolk
    p0400 egr failure will put it in limp mode, may want cleaning or replacing.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as pte say's clean out egr,not a bad job on the Dti,look inside manifold you will probably find the manifold need's a good clean
    wilts
    Thank guys it's not really the last two I'm bothered about, it's the first one, I have no idea what that is lol. The other two will probs just need a clean. Can any1 help?
    Hereford
    Hi Folks got a fault code of P1335, no rpm signal? (2L DTI Vectra 2002) Symtons are about five mins of starting the engine up the EM light comes on and the Rev counter drops to zero and the car goes into limp/ idle mode.
    This is intermiitent and if I floor the A/peddle it sometimes clears it. Any ideas
    wilts
    no one helpful on here then?
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    Quote Originally Posted by mats13 View Post
    How very polite.....not
    Do you not think that if people knew anything about code 1 then they would have posted their answer on here? Do you want everyone to post that they don't know just so you know people are looking at your post?
    Some people may not have a chance to see the post yet as they may be busy, so by all means bump the post, just try not to do it with a statement such as yours!
    We're all helpful if we can be
    wilts
    Quote Originally Posted by Waterboy View Post
    Lol wasn't meant in a horrible way. Just on abit of a deadline and I'm really busy atm so don't get to cheak this to offen.
    wilts
    bump
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
