Results 1 to 10 of 15
Thread: CD70 - Apologies for duff info!!
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Default CD70 - Apologies for duff info!!
    Well, sort of apologies...
    When I wired up my Cavalier to take a CD70 and GID, I went off TIS wiring diagrams.
    Anyway, today I pulled out the CD70 and CID from the Wifes Vectra Energy (March 2005) in order to fit a Nokia Blue tooth kit...CK variety not Vauxhall factory type.
    After bleating on for years about which wires go from the CD70 to the Display etc, I made a shocking discovery...
    Bearing in mind that the wife's sat nav works perfectly along with all BC functions etc - she has half the wires missing compared to what TIS says she should have
    According to TIS, there is an ABS wire to pin 37.....not on this vectra.
    There should be a serial data pair on pins 33 and 39...not on the wife's vectra.
    infact there was nothing in the two smaller blocks appertaining to pins 17 to 40!!
    So in essence, there is very little wiring needed to run a GID or CID..
    obviously the Vectra does have the rgb cable fitted.
    Here are the three pin outs as follows: -
    1st Image - What TIS says should be present
    2nd Image - What is actually present
    3rd Image - wires after fitting Nokia CK bluetooth kit.
    Hope this helps would be Mod-ers.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Good info mate was debating whether to go full canbus on mine and install a cd70 not sure about steering wheel controls though
    Irmscher Insignia CDTI 130
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    To be honest, If I had the choice I would have fitted the NCDC 2013 to my Cav.
    It has the multi changer and Sat Nav.
    The CD70 only has a single CD, unless you burn an MP3 disc, which can equate to upto 10 ordinary CD's..however you do get FREE TMC and dynamic guidance.
    I'm sure the NCDC2013 also has some other feature, which the CD70 doesn't.
    So on balance, I would say stick with the 2013.
    On a side note, I have just e-mailed Jaime on Omegaowners, as this "should" clear the way for fitting half can screen with a CD70...as per his rather odd query.
    If this can indeed be done, then I would be looking to fit an Omega GID, as this will directly take all my brown/white diagnostic feeds, that are handled on the Vectra by the main engine ECU.
    My BC functions would then also work...just looking for a cheap Omega GID to have a try with!!
    Regarding the wheel controls, I could be a simple matter of telling the CIM which controls you have, so that it may work...but I don't know for sure
    Further on the subject, I do believe that according to TIS (hmmmm do I believe what they say after my initial post above??)
    Both full and half can screens can be used, they just need to be wired up appropriately.
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    So it might be possible to wire a full can CID to my NCDC ?
    Ask jaime about GID mate i'm sure he could help
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Now it sounds intreresting
    either put a CD70 to my current cid.. or just put in a CD70 and normal CID ...
    Theres a option in tech2 to tell if you ahve buttons or scrools on your steering wheel..
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Well, I thought I'd let him try first, before throwing my money at a lost cause.
    I've told him that if he successfully fit's a half-can CID to his, then I would do the GID thing to mine...or perhaps a CID...who knows!!.
    Kman is more adamant that it won't fit / work.
    I bow to his superior screen modding knowledge, but don't know if he has actually attempted to cross the half can / full can boundaries.
    Twelve months ago, a full can CD70 could only be fitted to a Full Can Astra H, or Vectra-C and Signum.
    Recently it has been fitted to a non can cavalier mk3 and a few half can Corsa C's..with moderate, but not total success.
    I await the omega half can / full can hybrid fitment with interest.
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by kenp View Post
    Yes there are three options..
    Scroller wheels and buttons
    Just Buttons
    and No wheel controls
    There is another variance option of switches, which refers to the stalk switches on half can units.
    Regular Member rockonoli1's Avatar
    Telford
    Hello, Sorry to probably go off topic but just about to change from a vectra b to a sigum, are all cd70 navi mono chrome screens or colour? Cheers
    Engine : 2.2 Direct
    They can be both...
    Telford
    If it is monochrome can the screen be changed with out many prob?
  1. Duff CV, Hub or other?
    By rushy in forum Engine & Drivetrain
    Last Post: 29th February 2012, 02:06
  2. 2010/2011 CD70 Maps disk has traffic info
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2011, 19:24
  3. CD70 help & info required
    By chuckleuk in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2010, 15:41
  4. Have I got a duff motor??
    By Martin2.2 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2009, 18:06
  5. Playstation duff
    By MLC in forum Games Room
    Last Post: 27th April 2006, 14:14
