Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: The usual 1.9 cdti symtoms....
    Regular Member Geoff644NI's Avatar
    Cloughmills,Northern Ireland
    confused The usual 1.9 cdti symtoms....
    I have no power below 2000rpm on my cdti(150) and is seriously bugging me. I have took the egr apart and thoroughly cleaned it including taking the solenoid apart and making sure everything is free moving and it appears to be ok. I have also cleaned the boost sensor well with carb cleaner as well, but the car is no different. Also the intake manifold was changed a year ago and the 3rd injector plug has been changed so should rule them out. Any ideas? Im thinking it may need a new egr but i dont know why it would as everything seems to be moving freely. Any help greatly appreciated!
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    First thing you could try is remove all the injector plugs and clean them put all them back on but tie them one by one with tie wraps also put some injector cleaner in maybe you might have used some fuel that was bad? The problem is heat gets to the plugs .
    CHESHIRE
    hello geoff if yeah have done all of the above mate, it mite be worth trying some new heater/glow plugs just a thought .
    probably be worth holding back on the egr valve tho, because i myself bought a brand new egr valve last week for my car it ran great for three days then started playing up again ,ive more than likley wasted 100 quid on a new valve lol.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    geoff644ni do you use moores fuel my wifes zafira goes while bad on it , i only fill up at supervalue in ballymoney or the old 24hr in ballymena ,i have just bought a 150 and its doin the same but swirl bar is off and the egr needs cleaned
    Went out and tested the glow plugs and theres only 1 of them seems to work so ill get them changed today and see if that helps. Nah paedar i used to use moores petrol for scooter years ago and it struggled to run on it! I only ever go to the BP in ballymena or ballymoney so it's always good stuff goes in er. Injector plugs are all fine and the 3rd injector plug already had a cable tie on it just incase
    Full Member Big Sig's Avatar
    Check the bar is still on the swirl valves and that its not covered in crap.
    Aug 2007
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    how did you test them and how much were they
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Surely glo plugs won't affect the running of the CDTi, they only operate at startup, and even then only when its below a certain temperature (3° ??).
    exactly that Dan, they only aid in the startup.
    Thanks for the reply but the car is also smoking badly on startup when cold I should have maybe mentioned that, so hopefully the plugs will fix that.
    I just checked them by linking a piece of wire from the live terminal of the battery and the tip of the plug and watched/listened for any arcing, if they dont then they dont work.
    The swirl flaps are also all operating correctly and the link bar is still in place with no visible leakage around them.The only other update is that I fitted the fiat square egr gasket today so ill give it a few days and see if things improve.
  1. the usual q's
    By jays_225 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 17:49
  2. Symtoms of a broken front spring
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2011, 20:47
  3. Bleeding Flat Spot is back! Usual CDTI 150 Suspect!!!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 19th April 2011, 17:04
  4. What are the symtoms of fuel pressure reg fail on 2.2 direct?
    By big rich in forum Engine & Drivetrain
    Last Post: 8th February 2011, 09:17
  5. Not the usual mpg
    By simon5800 in forum General Chat
    Last Post: 20th June 2007, 16:21
