Results 1 to 3 of 3
Thread: swirl valves
    hull
    Default swirl valves
    hi all, i also got issues with my swirl valves tooooooo the bar also isnt connected,
    i got new modifed manifold frm vx today can any one tell me if i need to replace the egr valve aswell also do i need to replace the controll valve pls reply thanks 05 vectra cdti 150
    Oct 2009
    Teesside
    Hi mate, doing mine this weekend, you dont need to replace the EGR valve but good idea to clean it up, theres a how to on here somewhere.
    The control valve, do you mean the electronic module that controls the swirl valves, if so I think you do as your bar has come off therefore it will have gone out of range.
    Regular Member Dai69's Avatar
    Nr Welshpool
    Vehicle : Vec C Estate X 2
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    Done mine a few weeks ago. The "control valve" or "electronic module" - the actuator for the swirl valves, doesn't necessarily need to be replaced as the actuator will only learn its stroke when it is first powered up. as robert dale says, it's a good idea to give the egr a goodclean - follow the "how-to" and make sure you strip it completely & free up the solenoid part......
    http://www.vectra-c.com/forum/showthread.php?t=45867
    A helpful thread for changing the manifold......
    http://www.vectra-c.com/forum/showthread.php?t=102449
  1. Swirl valves on an '08
    By stevoxsi in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 22:11
  2. Swirl Valves......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 5th July 2012, 19:16
  3. re swirl valves
    By steve alan in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2012, 08:52
  4. Swirl valves
    By MattHD in forum Engine & Drivetrain
    Last Post: 18th April 2011, 12:45
  5. swirl valves
    By scoobyman in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2008, 21:14
