Thread: tail lights burning
    Regular Member suj786's Avatar
    glasgow
    Default tail lights burning
    put some led bulbs on my reg plate lights. they worked fine for a day or so then went off. then all sorts of bulb warning lights started coming up on dash (all rear passenger tail light) so I changed the reg plate light bulbs back to the standard bulbs. but bulb warning still coming on.
    checked the loom that plugs into the tail light and found that it had started to melt and burn slightly
    has this happened to anyone ?
    is the loom easy enough to change, or is it the light itself that needs changing ?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    have you tried changing the rear passenger tail light bulb, even if it appears to be ok?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    try putting all your bulbs back to standard matey.
    PaZ!
    glasgow
    bulbs are all standard, I only changed the ones that sit on top of the reg plate. but they've been changed back to standard now.
    Quote Originally Posted by Ian S100 View Post
    yeh, changed them all. still no luck. all the lights work fine, or all the lights don't work. more often not working than working.
  1. Tail lights?
    By Matt_Bankier in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2011, 09:17
  2. My New Led Tail Lights
    By 06bba04 in forum Styling
    Last Post: 2nd May 2011, 14:34
  3. Tail lights
    By johnsav in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2009, 20:26
