Results 1 to 3 of 3
Thread: Noise from front end of Vectra, help please
    Apr 2009
    leeds
    Default Noise from front end of Vectra, help please
    Hi,
    I have a Vectra 1.9 CDTI 120BHP on a 07 plate, car has done roughly 112k and for the past 20k it has been making a awful noise when ever I go for driving via lots of A roads.
    It started the second after I hit a pothole trying to avoid a tractor, I hit it doing about 45 and as soon as i'd cleared the tractor, there was a grinding/thumping sound coming from the front end.
    I stopped and checked the wheels and had a quick look under the front end but no visable damage.
    Now everytime I take it anywhere near any bumpy, hilly type A and B roads, the kind you find in the dales, etc, this noise starts again.
    On motorways it's fine and has no noise.
    The noise only starts when I go down a longish type hill after the driving of A and B roads for a while. This noise carries on getting louder and faster the more speed I pick up, so loud infact, that I can hear it from inside the car with the windows closed and doesn't stop until i reach the flat road and then speed upto about 60mph, at which point the noise is so fast, it feels something is gonna break and then it just goes !!
    Now for the strange bit, the noise carries on down the hill in everygear from 2nd to 6th and even in neutral, doesn't matter if i press the clutch down when in these gears, etc. Only thing that stops the noise is braking, but as soon as i lift off, the noise starts again.
    It has being into Evans Halshaw Horsforth in Leeds and they cannot find anything wrong with it.
    Any ideas of what this noise could be ? and do you think i'd be better off trying another garage for its next service in the next few months and see if they can find it. Evans Halshaw seem to inspect the wheel from behind with a torch and never take the thing off if the brakes look ok. Reckon they'd find something if they did it properly.
    I did speak to one of the tech guys and he said Vectra C's can suffer with gearbox issues, but as the noise goes when I brake and in neutral then I'm guessing its not a gearbox problem.
    Sorry for going on, but the noise is doing my head now on days outs,etc.
    Regular Member robster23's Avatar
    Hastings
    If this has happened following hitting a pot hole, i'd say the gearbox is an unlikely source of the noise. Although you say you can't see anything, the fact that a flat motorway causes no problem indicates that is is something to to with the suspension and supports. Has one side been damaged even a small amount? Has the tracking been altered by the pot hole?
    Has the bearing been damaged on one side? Has one of the inner wheel liners come loose a bit? I think sadly, it will be a slow process of elimination. Good luck!
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Get the wheel off and check all bushes/drop links/ARB bush and spring.
    Sounds like a spring snapped.
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. Vectra 2003 2.2 SRI DTI front creaking noise
    By ramzy304 in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2010, 21:57
  3. Noise from front end of Vectra through wheels ?, help please
    By da_melonuk in forum Suspension, Wheels & Brakes
    Last Post: 20th April 2010, 19:17
  4. loud noise from front of vectra sri
    By tractordriver28 in forum Suspension, Wheels & Brakes
    Last Post: 28th January 2009, 23:02
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
