Thread: Glow plugs
    Sunerland
    Question Glow plugs
    A few questions guys
    2ltr DTI
    GLOW PLUGS
    What make would you recommend ?
    What sort of price am i looking at paying for a full set of good quality plugs ?
    Do you need a special tool to take them out ?
    Would you recommend them to be fitted by dealers or DIY ?
    I know they only take about 10 minutes to fit but all the stories ive heard about them snapping inside the head its got me worried.
    Just wondering what you have done to overcome this fear.
    regards,
    Steve.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    What make would you recommend ? Bosch or genuine VX
    What sort of price am i looking at paying for a full set of good quality plugs ? About 40 quid
    Do you need a special tool to take them out ? The most special tool is your hands, be careful removing the leads from them as the clips are delicate. Just a deep socket for the plugs themselves
    Would you recommend them to be fitted by dealers or DIY ? How confident are you? If you snap one its a head off job to fix. I recommend starting the engine to heat it up a fair bit first and use a drop of coppaslip on the threads of the new plugs.
    Most of all BE GENTLE!
    Sunerland
    AWW cheers John you have come to my rescue once again,
    the reason i suspect the plugs is because /Saturday night i did about 35 miles in my car it ran brilliantly. Today i went to start the car outside temp 12.5 and the damn thing struggled to start and when it did i got white-ish blue smoke coming out of the back on start up.
    If not plugs...... injector seals maybe ?
    Regards,
    Steve.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Or it may be the leak off pipes mate, there will be a how2 going up for this shortly. Try the plugs first as it won't do any harm (assuming you get them all out lol)
    Sunerland
    Ha Ha now you are really making me nervious
    Nottinghamshire
    If one or more of the glowplugs or the glowplug relay had failed, you'd have a warning light (car and spanner) on the dash. As John said, difficult starting is more likely to be caused by an air leak which causes the fuel to run back towards the tank so the pump has to draw it back through before the engine will start.
    When is the car difficult to start? Is it all the time, or is it perhaps when it has been left for a long time, or perhaps when it has been parked with the front facing uphill?
    You can help to prove the air leak theory by leaving the car parked with the nose pointing down (especially when the car will be left standing overnight or longer) and seeing if that helps - gravity helps stop the fuel running back towards the tank.
    Motherwell Scotland
    I did mine recently because of poor starting but it made no difference. Tools you will need are 1/4 drive, 10mm deep socket, 1/4 drive long extension bar, 1/4 drive knuckle joint and long nose pliers, I invested in the extra long type and it made the job fairly straightforward. As the man said, take you time and go easy. Mine were not difficult to come out.
    Motherwell Scotland
    Mambo, sorry, just noticed you have the 2.0 dti. I have the 1.9 cdti 120. Sorry for the confusion mate.
    Regular Member yadziyad's Avatar
    London
    hi guys ive got the same sort of issues, how much will dealers charge to fit them.
  1. Glow plugs?
    By SEANYboi in forum Engine & Drivetrain
    Last Post: 11th February 2013, 10:00
  2. Which glow plugs for 1.9 150?
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 12:01
  3. Glow Plugs
    By RobW in forum Engine & Drivetrain
    Last Post: 18th March 2011, 20:05
  4. Glow plugs
    By danny1992 in forum Engine & Drivetrain
    Last Post: 9th September 2010, 11:52
  5. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
