Results 1 to 2 of 2
Thread: More help needed!!!!
    Jul 2009
    N. Ireland
    Default More help needed!!!!
    Hi all,
    Car was going well after the inlet manifold was changed. Today however, i went out to start the car and it wouldnt start. Give it a push and it started no problem but turned it off and it wouldnt fire again. There is no problem with the battery so i think its the starter that's f##ked up. I tapped the started this evening while my friend was turning the key and it started. Question is, has anyone had a similar problem? If so, is it hard to change the starter and how much does a new one cost?? By looking at it, it is going to be pretty hard to get it changed.
    By the way, the car is a 05 Vec C 1.9cdti 150
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    have a look on ebay for a recon unit, it will be much cheaper than a brand new one
    Midlands Mod Shop - NFFC.
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
