Results 1 to 10 of 13
Thread: Torque screws
    Sunerland
    Question Torque screws
    Hi guys,
    I was going to be taking my front bumper off today but had trouble with the 3 torque screws which are in the wheel arch that keep the inner lining in place THEY are ROUNDED
    Any idea how to get them out I thought about drilling them but wondered if it would damage the piece they are screwed into.
    Also can replacements be bought at motor factors or is it dealers only ?
    Has anyone else had this problem, if yes how did you solve it ?
    Any suggestions will be greatfully accepted.
    Steve.
    I have had that problem, used a pair of pipe/water pump pliers to grip the heads.
    iirc they are like self tapping screws
    Regular Member paul.sessions's Avatar
    leighton buzzard
    flat head screw driver, pliers thats what i used when i got trouble with one..
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    any way realy but you will need the red captive nuts that go on the bumper
    leighton buzzard
    yeah they are self tappers
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Use a hack saw blade and cut into the top... then a flathead as paul said...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Drill the heads off them mate, even if you do knacker the bit behind them they can be bought as they clip into the hole and thats what you screw into, only a few pence too
    Sunerland
    Awww guys you are the best,
    "Wow the speed of the replies im very impressed"
    THANK YOU ALL
    I think a trip to M factors tomorrow to get replacemnts then.......
    Watch this space for an update
    Mind you it won't probably get done til Tuesday or Thursday now, but i will report back.
    Thanx again guys.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I used a electric angle grinder today to remove a rounded torx screw when doing my fog lights.
    Very carefully (obviously) removed the head off the screw and when flat to the backing washer it simply popped off.I was then able to remove the remains with a pair of molegrips.
    Feb 2007
    North west
    You can sometimes remove stuck screws by running a drill in reverse so the action of the drill bit turning starts the screw unfastening even if it was snapped by being overtightened.
  1. EGR Screws issue?????
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 3rd September 2012, 13:40
  2. big screws
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2012, 15:28
  3. Air Box screws
    By irmscherTI in forum Diesel Engine related
    Last Post: 2nd June 2007, 20:56
vauxhall vectra inner lining screes
