Thread: Flat spot help needed
    newcastle
    Default Flat spot help needed
    I drive a 2.0dti since i put a tunit box on i notice a real bad flat spot just at 2000RPM til 2500 RPM really notice it in 4th gear is this the air flow meter or boost pressure sensor
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Could be anything tbh, bust hose, egr valve jamming open, clogged boost sensor and pretty much anything else.
    Have you removed box to see if that resolves the issue could be as simple as the engine doesnt like the box.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Regular Member yadziyad's Avatar
    London
    try disconnecting the battery for 20 minutes so the ecu learns the new setup
    newcastle
    have had it on the computer and boost pressure sensor came up on it and it does make a swirly noise when i turn the car offV
    Boldon
    Does the flatspot go when you remove the tuning box? pressure sensor faults are common with boxes fitted as the ECu sees the higher fuel pressure as a fault and tries to raise boost level accordingly but cant and gives an implausible signal that triggers the fault code. This is true for most DTI engines, not necessarily the vaux 2.0 DTi, just a suggestion.
  1. Flat spot
    By marc vectra sri in forum The 'Off Topic' room
    Last Post: 12th August 2012, 19:38
  2. flat spot but different
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 28th July 2012, 11:40
  3. 1.8 flat spot...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2009, 09:25
  4. Flat spot!
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 09:43
  5. flat spot
    By surreyl31 in forum Petrol Engine related
    Last Post: 16th July 2007, 18:41
vectra c 2.0dti air mass meter faults www.vectra-c.com
