Thread: ****** light out bulb warning and indicator
    edinburgh
    Default ****** light out bulb warning and indicator
    Hi all. for a few weeks now my light bulb warning light has been on the dashboard, when i put the headlights on my left indicator light illuminates all the time. i have reboted and unplugged the battery and checked remover and refitted every light bulb on the car and still have the same problem. does anyone have any suggestions?
    thanks all.
    Graham
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Left side front side light bulb failure will cause this. If the bulb looks like it is working, replace it anyway. At least it's the easy side, just open the battery cover, and twist and pull out the washer filler neck to improve access.
    Full Member Big Sig's Avatar
    edinburgh
    Thanks guys. spent an hour today and managed to locate the troublesome bulb! indicator light went out and all seemed ok! right hand buld went on but discovered the sidelight bulb blew after changing the other. both changed and car good as new!
    Thanks again
  1. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  2. bulb warning light
    By magpie27 in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2009, 12:21
  3. indicator bulb on head light
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2009, 22:43
  4. Light Warning Indicator.
    By Stevie-B in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2008, 13:50
  5. Help! - Control Indicator for Exhaust Warning Light
    By Madders in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2007, 20:21
