Thread: White foam in coolant tank
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default White foam in coolant tank
    White non oily foam is forming in the coolant bottle. Head gasket or something else?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    is the cooling system pressurizing,if so you may have a failed head gasket.if not you may have an oil cooler failure,,as the oil pressure is higher than coolant pressure the oil will enter the cooling system
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Didn't notice any pressure when I opened the tank, just a quiet hiss.
    Mileage : 000
    Is there any water dropplets on the oil dip stick. From the sound of it the head gasket has gone. Also is there an excesive amount of "steam" coming out of the exhaust.
    Regular Member ptrehearn152's Avatar
    norfolk
    for head gasket look for white smoke from exhaust, increase in oil level, increase in pressure in cooling system, loss of power, engine suddenly turning over slowly then quickly when trying to start like flat battery, would drain and flush cooling system out first before tackling head gasket, may not cure it but best to start with cheaper options first.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    if yours is a auto it could be gearbox oil due to the rad cooler failing
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The oil is fine and there is no excessive white smoke. It starts ok and goes well. It's a manual so the only oil cooler it's got is the engine oil cooler.
    Will make the dealer flush the cooling system, as there is also a grinding noise coming from the belt area and I suspect a faulty water pump.
  1. spanner light and foam in coolant
    By Slick_richie in forum Engine & Drivetrain
    Last Post: 17th January 2012, 21:17
  2. Coolant Expansion Tank
    By Telboy in forum Engine & Drivetrain
    Last Post: 2nd May 2011, 21:11
  3. coolant tank cap
    By melvin in forum Engine & Drivetrain
    Last Post: 4th December 2010, 00:05
  4. Split Coolant tank 2.8 V6
    By luke4487 in forum Engine & Drivetrain
    Last Post: 1st November 2009, 10:16
  5. Coolant tank
    By John2360 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 14:09
foam in the coolant reservoir
foam in coolant reservoir
white foam in expansion tank
vectra c froth in expansion bottle
white foam in the cooler tank
white froth in expansion tank
astra h froth in coolant
foam in coolant bottle
white foam in coolant reservoir
white scum in car expansion tank
foam in header tank
fine foam in coolant tank
suzuki wagon forum foam in coolant
foam in vauxhall zafira header tank
white foam in header tank
Coolant tank
white froth coming out of coolant top
vauxhall vectra white foam in header tank
