Results 1 to 10 of 21
Thread: I'm Backkkkkkkkk
    Regular Member Perry's Avatar
    Watford Herts
    Default I'm Backkkkkkkkk
    After selling the Signum and going to an Astra for a while, and then a dreadful Pug 307, I am now back in a Vectra-C again :-)
    52 plate with Irmscher goodies galore and 19" snowflakes to boot.
    However I do have a couple fo questions, it has had a MIJ cat back dual exit , exhaust fitted, that (now I am a bit older) is too loud for my liking, so I am going to take it off, do I need to just change the 2 rear boxes or do they remove a middlebox as well meaing I would require a cat back system??? I have seen a dual exit section on ebay so need to know.
    Other bit is the cruise control button seems a bit dodgy ie press it and the green symbol on dash flashes once but does not function any ideas on this??
    Thanks and nice to be back and promise pictures tomorrow :-)
    Regular Member jlock's Avatar
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Engine : 2.5l Straight 6
    What engine have you got?
    And how loud is the exhaust?
    Sunny Dartmoor
    Back Perry
    Depends whats been fitted to your car Perry,i'd guess that it would be a Cat-back system,cruise control might be the a weak spring on the Clutch pedal,hth...........
    Watford Herts
    Cheers, it's the 2.2 engine (not direct) and quite loud, nice sounding on tick over but noisier if you put your foot down!!
    glenboy, on the receipt it says cat back, so would I need to replace the whole exhaust from cat back again??
    Maybe swap with someone ??
    As for CC how would I check the spring?? Or is it something I can't ??
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    I could be up for a swap as i have a standard twin setup?..
    You could try and lift the clutch pedal from below with your foot to make sure its up at its highest point and see if the cruise control works then?
    Watford Herts
    Thanks jlock, will try clutch pedal tomorrow, will keep you informed on exhaust as would need to get up to you or down to me etc and are you any good at changing them with my help?? lol
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    I dont have a clue about changing them tbh but would be worth a go i guess... unless you knew someone else who could help and i could pop down
    Watford Herts
    By the way should be able to see exhaust on this link........
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    Watford Herts
    Leave it with jlock, and I will see what can be done.
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Sounds good fella
